Disassembling Macintosh IIsi Floppy Drive
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: step 1, image 1 of 2 Disassembling Macintosh IIsi Floppy Drive, Top Case: step 1, image 2 of 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: step 2, image 1 of 3 Disassembling Macintosh IIsi Floppy Drive: step 2, image 2 of 3 Disassembling Macintosh IIsi Floppy Drive: step 2, image 3 of 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: step 3, image 1 of 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: step 3, image 2 of 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: step 3, image 3 of 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: step 4, image 1 of 3 Disassembling Macintosh IIsi Floppy Drive: step 4, image 2 of 3 Disassembling Macintosh IIsi Floppy Drive: step 4, image 3 of 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
2 other people completed this guide.
Chris Green
38,143 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
1 Guide Comment
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,954
