Disassembling Marshall MS-2 Partner Circuit Board
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: step 1, image 1 of 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: step 2, image 1 of 3 Disassembling Marshall MS-2 Partner Circuit Board: step 2, image 2 of 3 Disassembling Marshall MS-2 Partner Circuit Board: step 2, image 3 of 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: step 3, image 1 of 2 Disassembling Marshall MS-2 Partner Circuit Board: step 3, image 2 of 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: step 4, image 1 of 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: step 5, image 1 of 2 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: step 5, image 2 of 2
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: step 6, image 1 of 1
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: step 7, image 1 of 1
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
3 other people completed this guide.
MacKinley
816 Reputation
5 Guides authored
1 Guide Comment
There Is a toroidal transformer inside ?
Jack redmond - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 2,049
