Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case
  1. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: step 1, image 1 of 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case, Case: step 1, image 2 of 2
    • Turn the speaker face down, so the connector side is up.
    • Remove the four #2 Philips screws on the back plate.
  2. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: step 2, image 1 of 1
    • Remove the foam insert to expose the two spade connectors.
    • Carefully separate the connectors
  3. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: step 3, image 1 of 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: step 3, image 2 of 2
    • Turn the speaker so the grill side is up.
    • Remove the four screws on the grill. I had to use a t-10 Torx bit to remove them.
    • The grill is not glued on, but may require a bit of prying to remove.
  4. Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: step 4, image 1 of 2 Disassembling Meyer Sound MM-4 Ultra Compact Wide-Range Loudspeaker Case: step 4, image 2 of 2
    • Remove the four silver bolts holding the speaker in place. These bolts also have threads inset for the grill screws to fit into.
    • This is a pretty quick and easy teardown, not too many parts in this one. The meyer speaker's part number is ST-164. It's a 16 Ohm driver.
4 other people completed this guide.
RoggeSound
2,345 Reputation
1 Guide authored
2 Comments
So I took one of my MM-4 apart because something was rattling. Turns out it has a loose magnet assembly. It must have been dropped in shipping.
Garrett McWilliams - Reply
Do you by any chance still have it?
I have two of them already and with some zipties and rubber they sound great again…
Would you by any chance ship the broken driver over to me?
Jan Marius -
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 9
All Time: 6,795
