Disassembling Motorola i90c Keypad
  1. Disassembling Motorola i90c Keypad, Battery: step 1, image 1 of 3 Disassembling Motorola i90c Keypad, Battery: step 1, image 2 of 3 Disassembling Motorola i90c Keypad, Battery: step 1, image 3 of 3
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Keypad: step 2, image 1 of 3 Disassembling Motorola i90c Keypad: step 2, image 2 of 3 Disassembling Motorola i90c Keypad: step 2, image 3 of 3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Keypad, Antenna: step 3, image 1 of 2 Disassembling Motorola i90c Keypad, Antenna: step 3, image 2 of 2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Keypad, Midframe: step 4, image 1 of 3 Disassembling Motorola i90c Keypad, Midframe: step 4, image 2 of 3 Disassembling Motorola i90c Keypad, Midframe: step 4, image 3 of 3
    • Unscrew the 3 screws shown.
    • Lift the right part of the Nextel logo
    • Remove the screw underneath.
  5. Disassembling Motorola i90c Keypad: step 5, image 1 of 2 Disassembling Motorola i90c Keypad: step 5, image 2 of 2
    • Forcing the cover off could damage the ribbon cable, so be careful when doing so.
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Keypad: step 6, image 1 of 3 Disassembling Motorola i90c Keypad: step 6, image 2 of 3 Disassembling Motorola i90c Keypad: step 6, image 3 of 3
    • Find the connection between the headphone jack and logic board.
    • Begin separating the two pieces, slowly and carefully.
  7. Disassembling Motorola i90c Keypad, Logic Board: step 7, image 1 of 2 Disassembling Motorola i90c Keypad, Logic Board: step 7, image 2 of 2
    • Lift the first logic board off of the rest of the device.
  8. Disassembling Motorola i90c Keypad: step 8, image 1 of 1
    • Gently lift the second logic board from the rest of the device.
    • DO NOT force the board straight off as it could damage the ribbon cable!
  9. Disassembling Motorola i90c Keypad: step 9, image 1 of 2 Disassembling Motorola i90c Keypad: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, carefully pull off the connector shown.
  10. Disassembling Motorola i90c Keypad, Keypad: step 10, image 1 of 3 Disassembling Motorola i90c Keypad, Keypad: step 10, image 2 of 3 Disassembling Motorola i90c Keypad, Keypad: step 10, image 3 of 3
    • Remove the keypad buttons off the front cover of the phone.
Jorge
4 Reputation
4 Guides authored
Cal Poly, Team 29-61, Johann Spring 2010 Member of Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,454
