Disassembling NEC LCD1770NX Monitor Enclosure
  1. Disassembling NEC LCD1770NX Monitor Enclosure, Stand: step 1, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure, Stand: step 1, image 2 of 2
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Monitor Enclosure: step 2, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure: step 2, image 2 of 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Monitor Enclosure: step 3, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure: step 3, image 2 of 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Monitor Enclosure: step 4, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure: step 4, image 2 of 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Monitor Enclosure: step 5, image 1 of 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Monitor Enclosure: step 6, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure: step 6, image 2 of 2
    • Lift the the stand straight up to remove it.
  7. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: step 7, image 1 of 3 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: step 7, image 2 of 3 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: step 7, image 3 of 3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. Disassembling NEC LCD1770NX Monitor Enclosure: step 8, image 1 of 3 Disassembling NEC LCD1770NX Monitor Enclosure: step 8, image 2 of 3 Disassembling NEC LCD1770NX Monitor Enclosure: step 8, image 3 of 3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. Disassembling NEC LCD1770NX Monitor Enclosure: step 9, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure: step 9, image 2 of 2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. Disassembling NEC LCD1770NX Monitor Enclosure: step 10, image 1 of 1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. Disassembling NEC LCD1770NX Monitor Enclosure: step 11, image 1 of 3 Disassembling NEC LCD1770NX Monitor Enclosure: step 11, image 2 of 3 Disassembling NEC LCD1770NX Monitor Enclosure: step 11, image 3 of 3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. Disassembling NEC LCD1770NX Monitor Enclosure: step 12, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure: step 12, image 2 of 2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. Disassembling NEC LCD1770NX Monitor Enclosure: step 13, image 1 of 2 Disassembling NEC LCD1770NX Monitor Enclosure: step 13, image 2 of 2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
2 other people completed this guide.
John Patterson
253 Reputation
2 Guides authored
Cal Poly, Team 11-36, Amido Fall 2013 Member of Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Members
7 Guides authored
One Comment
very helpful
Thank you
Richard Morgan - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 25
All Time: 5,838
