Disassembling NEC LCD1770NX Stand
  1. Disassembling NEC LCD1770NX Stand, Stand: step 1, image 1 of 2 Disassembling NEC LCD1770NX Stand, Stand: step 1, image 2 of 2
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Stand: step 2, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 2, image 2 of 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Stand: step 3, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 3, image 2 of 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Stand: step 4, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 4, image 2 of 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Stand: step 5, image 1 of 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Stand: step 6, image 1 of 2 Disassembling NEC LCD1770NX Stand: step 6, image 2 of 2
    • Lift the the stand straight up to remove it.
Michela Upson
110 Reputation
1 Guide authored
Cal Poly, Team 11-36, Amido Fall 2013 Member of Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,426
