Disassembling Nerf Recon CS-6 Shell
  1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: step 1, image 1 of 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
  2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: step 2, image 1 of 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: step 3, image 1 of 2 Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: step 3, image 2 of 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: step 4, image 1 of 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: step 5, image 1 of 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: step 6, image 1 of 2 Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: step 6, image 2 of 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
12 other people completed this guide.
Asad Qureshi
595 Reputation
3 Guides authored
Baylor, Team 8-14, Williams Fall 2014 Member of Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Members
6 Guides authored
2 Guide Comments
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - Reply
very useful, thanks!
Sebastian Isaacs - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 12,504
