Disassembling Netatmo Outdoor Camera Main Unit
  1. Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: step 1, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit, Main Unit: step 1, image 2 of 2
    • Remove the plate at the bottom of the camera by inserting a screwdriver in the slot, and bending while pulling.
    • The panel will lift up and can be removed.
  2. Disassembling Netatmo Outdoor Camera Main Unit: step 2, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 2, image 2 of 2
    • Insert a flathead screwdriver into each hole at the front of the camera and push the two tabs to the centre and forwards.
    • It's hard to see, but you need the triangular part at the front, rather than what appears to be a tab at the back.
    • Pushing towards the centre allows the lens cover to come off. These can be done one at a time.
  3. Disassembling Netatmo Outdoor Camera Main Unit: step 3, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 3, image 2 of 2
    • Remove the six 2.5mm hex screws using a long Allen key.
    • One screw has an earthing ring wire. Don't forget this when reassembling.
  4. Disassembling Netatmo Outdoor Camera Main Unit: step 4, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 4, image 2 of 2
    • Separate the two pieces by pulling slightly on the lower module.
    • Pull the metal housing forward.
    • Pushing the light from the inside can help in removing the shell.
  5. Disassembling Netatmo Outdoor Camera Main Unit: step 5, image 1 of 1
    • Using a 1.5mm hex screwdriver remove the four screws holding on the camera module.
  6. Disassembling Netatmo Outdoor Camera Main Unit: step 6, image 1 of 2 Disassembling Netatmo Outdoor Camera Main Unit: step 6, image 2 of 2
    • From this point the housing can be worked up and diagonally to reveal the circuit board, and ribbon cable.
    • Be careful with both the camera module ribbon and the one for the LED lights (which cannot be removed).
    • Do not slide the circuit board within the heatsink otherwise you risk ripping the LED ribbon cable.
The Virtual Traveller
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 96
All Time: 663
