Disassembling Nokia 1100b RH-36
  1. Disassembling Nokia 1100b RH-36, Battery Cover: step 1, image 1 of 2 Disassembling Nokia 1100b RH-36, Battery Cover: step 1, image 2 of 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Disassembling Nokia 1100b RH-36, Battery: step 2, image 1 of 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Disassembling Nokia 1100b RH-36, Front Cover: step 3, image 1 of 2 Disassembling Nokia 1100b RH-36, Front Cover: step 3, image 2 of 2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  4. Disassembling Nokia 1100b RH-36, Inner Casing: step 4, image 1 of 2 Disassembling Nokia 1100b RH-36, Inner Casing: step 4, image 2 of 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
6 other people completed this guide.
JSwan
805 Reputation
6 Guides authored
Cal Poly, Team 10-43, Amido Spring 2013 Member of Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 2,580
