Disassembling Nokia 2366i Front Cover
  1. Disassembling Nokia 2366i Front Cover, Battery: step 1, image 1 of 2 Disassembling Nokia 2366i Front Cover, Battery: step 1, image 2 of 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Front Cover: step 2, image 1 of 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Front Cover: step 3, image 1 of 3 Disassembling Nokia 2366i Front Cover: step 3, image 2 of 3 Disassembling Nokia 2366i Front Cover: step 3, image 3 of 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Front Cover, Front Cover: step 4, image 1 of 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Front Cover: step 5, image 1 of 2 Disassembling Nokia 2366i Front Cover: step 5, image 2 of 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Front Cover: step 6, image 1 of 2 Disassembling Nokia 2366i Front Cover: step 6, image 2 of 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
Kristen
187 Reputation
1 Guide authored
Cal Poly, Team 1-14, Amido Winter 2011 Member of Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 1,323
