Disassembling Nokia 2366i Motherboard
  1. Disassembling Nokia 2366i Motherboard, Battery: step 1, image 1 of 2 Disassembling Nokia 2366i Motherboard, Battery: step 1, image 2 of 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Motherboard: step 2, image 1 of 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Motherboard: step 3, image 1 of 3 Disassembling Nokia 2366i Motherboard: step 3, image 2 of 3 Disassembling Nokia 2366i Motherboard: step 3, image 3 of 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Motherboard, Rear Case: step 4, image 1 of 2 Disassembling Nokia 2366i Motherboard, Rear Case: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Motherboard: step 5, image 1 of 2 Disassembling Nokia 2366i Motherboard: step 5, image 2 of 2
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Motherboard: step 6, image 1 of 2 Disassembling Nokia 2366i Motherboard: step 6, image 2 of 2
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Motherboard: step 7, image 1 of 1
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
  8. Disassembling Nokia 2366i Motherboard, Motherboard: step 8, image 1 of 2 Disassembling Nokia 2366i Motherboard, Motherboard: step 8, image 2 of 2
    • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
  9. Disassembling Nokia 2366i Motherboard: step 9, image 1 of 2 Disassembling Nokia 2366i Motherboard: step 9, image 2 of 2
    • Rotate the phone counterclockwise so that the edge is facing you.
    • Use the spudger to lift the motherboard out of the base of the phone.
    • Remove the motherboard from the base of the phone.
Jonathan Newman
486 Reputation
4 Guides authored
Cal Poly, Team 1-14, Amido Winter 2011 Member of Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Members
17 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,534
