Nokia 3100b Microphone Replacement
  1. Nokia 3100b Microphone Replacement, Battery: step 1, image 1 of 1
    • Make sure your phone is turned off.
  2. Nokia 3100b Microphone Replacement: step 2, image 1 of 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Microphone Replacement, SIM Card: step 3, image 1 of 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Microphone Replacement: step 4, image 1 of 1
    • Retrieve your SIM card.
  5. Nokia 3100b Microphone Replacement, Microphone: step 5, image 1 of 1
    • Press the black tabs to release the front cover from the phone.
  6. Nokia 3100b Microphone Replacement: step 6, image 1 of 1
    • Remove the front cover from the phone.
    • Set the front cover as indicated, aside.
  7. Nokia 3100b Microphone Replacement: step 7, image 1 of 2 Nokia 3100b Microphone Replacement: step 7, image 2 of 2
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  8. Nokia 3100b Microphone Replacement: step 8, image 1 of 3 Nokia 3100b Microphone Replacement: step 8, image 2 of 3 Nokia 3100b Microphone Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Note the location of the microphone.
    • Use tweezers to remove the microphone from the phone's base.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Sterling Fuentes
130 Reputation
8 Guides authored
Cal Poly, Team 29-64, Johann Spring 2010 Member of Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 2,216
