Disassembling Nokia 6236i Keypad
  1. Disassembling Nokia 6236i Keypad, Battery: step 1, image 1 of 2 Disassembling Nokia 6236i Keypad, Battery: step 1, image 2 of 2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Disassembling Nokia 6236i Keypad: step 2, image 1 of 3 Disassembling Nokia 6236i Keypad: step 2, image 2 of 3 Disassembling Nokia 6236i Keypad: step 2, image 3 of 3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Disassembling Nokia 6236i Keypad, Front Casing: step 3, image 1 of 3 Disassembling Nokia 6236i Keypad, Front Casing: step 3, image 2 of 3 Disassembling Nokia 6236i Keypad, Front Casing: step 3, image 3 of 3
    • Insert a spudger into the indention on the bottom right side of the device.
    • Slide the spudger upward to a second indention at the top of the phone.
    • The front casing will detach from the phone.
  4. Disassembling Nokia 6236i Keypad, Keypad: step 4, image 1 of 1
    • With the front casing removed, the keypad can easily be pulled off the back of the front casing.
    • In all probability, it will already have fallen out and no removal is required.
Erik Lindahl
63 Reputation
4 Guides authored
Cal Poly, Team 10-46, Garner Spring 2010 Member of Cal Poly, Team 10-46, Garner Spring 2010
CPSU-GARNER-S10S10G46
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 990
