Disassembling Numark TT1600 Circuit board
  1. Disassembling Numark TT1600 Circuit board, Circuit board: step 1, image 1 of 2 Disassembling Numark TT1600 Circuit board, Circuit board: step 1, image 2 of 2
    • Flip over the turntable and remove the nine screws on the outer edges.
  2. Disassembling Numark TT1600 Circuit board: step 2, image 1 of 1
    • Remove the back cover by pulling it apart.
  3. Disassembling Numark TT1600 Circuit board: step 3, image 1 of 1
    • Locate the largest circuit board inside the device.
  4. Disassembling Numark TT1600 Circuit board: step 4, image 1 of 1
    • Locate the wires that are plugged into the side of the circuit board.
  5. Disassembling Numark TT1600 Circuit board: step 5, image 1 of 2 Disassembling Numark TT1600 Circuit board: step 5, image 2 of 2
    • Gently pull out the wires plugged into the circuit board.
  6. Disassembling Numark TT1600 Circuit board: step 6, image 1 of 2 Disassembling Numark TT1600 Circuit board: step 6, image 2 of 2
    • Once the wires are unplugged you will notice two more wires plugged into the bottom of the circuit board.
    • Note that these wires are soldered onto the circuit, indicated by the red markers.
    • To completely remove the circuit board these wires must be removed.
Sukhjinder
17 Reputation
1 Guide authored
Cal Poly, Team 17-14, Regan Fall 2011 Member of Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,550
