Disassembling Olympus Stylus 1010 Case
  1. Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: step 1, image 1 of 2 Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: step 1, image 2 of 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Disassembling Olympus Stylus 1010 Case: step 2, image 1 of 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Disassembling Olympus Stylus 1010 Case: step 3, image 1 of 2 Disassembling Olympus Stylus 1010 Case: step 3, image 2 of 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Disassembling Olympus Stylus 1010 Case: step 4, image 1 of 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Disassembling Olympus Stylus 1010 Case: step 5, image 1 of 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Disassembling Olympus Stylus 1010 Case: step 6, image 1 of 3 Disassembling Olympus Stylus 1010 Case: step 6, image 2 of 3 Disassembling Olympus Stylus 1010 Case: step 6, image 3 of 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Disassembling Olympus Stylus 1010 Case: step 7, image 1 of 3 Disassembling Olympus Stylus 1010 Case: step 7, image 2 of 3 Disassembling Olympus Stylus 1010 Case: step 7, image 3 of 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
Max McIntyre
544 Reputation
4 Guides authored
Cal Poly, Team 13-4, Forte Winter 2011 Member of Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Members
12 Guides authored
1 Guide Comment
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 61
All Time: 3,404
