Disassembling Olympus Stylus Tough 6020 Prerequisite Guide
  1. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Battery: step 1, image 1 of 1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: step 2, image 1 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: step 2, image 2 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: step 2, image 3 of 3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: step 3, image 1 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: step 3, image 2 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: step 3, image 3 of 3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: step 4, image 1 of 2 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: step 4, image 2 of 2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: step 5, image 1 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: step 5, image 2 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: step 5, image 3 of 3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: step 6, image 1 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: step 6, image 2 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: step 6, image 3 of 3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: step 7, image 1 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: step 7, image 2 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: step 7, image 3 of 3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Back Plate: step 8, image 1 of 1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: step 9, image 1 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: step 9, image 2 of 3 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: step 9, image 3 of 3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 805
