Disassembling Panasonic GU87 LCD Main Board
  1. Disassembling Panasonic GU87 LCD Main Board, LCD Cover removal: step 1, image 1 of 1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 LCD Main Board: step 2, image 1 of 1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 LCD Main Board, LCD: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 LCD Main Board: step 4, image 1 of 1
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
  5. Disassembling Panasonic GU87 LCD Main Board, Main Board: step 5, image 1 of 1
    Buy
    • Unlock the LCD connectors shown in red boxes on the picture .
    • Use tweezers as necessary.
  6. Disassembling Panasonic GU87 LCD Main Board: step 6, image 1 of 1
    • Place finger nails on the connector tab as shown.
    • Lift the connector tab up.
  7. Disassembling Panasonic GU87 LCD Main Board: step 7, image 1 of 1
    • Pull/pivot the LCD main board as shown in order to remove.
Van
7 Reputation
8 Guides authored
Cal Poly, Team 2-10, Johann Summer 2010 Member of Cal Poly, Team 2-10, Johann Summer 2010
CPSU-JOHANN-R10S2G10
4 Members
20 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 26
All Time: 1,944
