Disassembling Pentax K200D Front Cover
  1. Disassembling Pentax K200D Front Cover, Preparation: step 1, image 1 of 1
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: step 2, image 1 of 1
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: step 3, image 1 of 1
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: step 4, image 1 of 1
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
9 other people completed this guide.
Rick Nelson
706 Reputation
1 Guide authored
Master Techs Member of Master Techs
Community
331 Members
1,458 Guides authored
1 Guide Comment
How do l clean the prisum…
brett_lorking - Reply
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 77
All Time: 7,343
