Disassembling Planet Eclipse Geo3 Body
  1. Disassembling Planet Eclipse Geo3 Body, Grip: step 1, image 1 of 2 Disassembling Planet Eclipse Geo3 Body, Grip: step 1, image 2 of 2
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Disassembling Planet Eclipse Geo3 Body: step 2, image 1 of 2 Disassembling Planet Eclipse Geo3 Body: step 2, image 2 of 2
    • Pull the grip away from the frame.
  3. Disassembling Planet Eclipse Geo3 Body: step 3, image 1 of 2 Disassembling Planet Eclipse Geo3 Body: step 3, image 2 of 2
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Disassembling Planet Eclipse Geo3 Body, Macroline: step 4, image 1 of 3 Disassembling Planet Eclipse Geo3 Body, Macroline: step 4, image 2 of 3 Disassembling Planet Eclipse Geo3 Body, Macroline: step 4, image 3 of 3
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Disassembling Planet Eclipse Geo3 Body: step 5, image 1 of 3 Disassembling Planet Eclipse Geo3 Body: step 5, image 2 of 3 Disassembling Planet Eclipse Geo3 Body: step 5, image 3 of 3
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Disassembling Planet Eclipse Geo3 Body, Body: step 6, image 1 of 3 Disassembling Planet Eclipse Geo3 Body, Body: step 6, image 2 of 3 Disassembling Planet Eclipse Geo3 Body, Body: step 6, image 3 of 3
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Disassembling Planet Eclipse Geo3 Body: step 7, image 1 of 3 Disassembling Planet Eclipse Geo3 Body: step 7, image 2 of 3 Disassembling Planet Eclipse Geo3 Body: step 7, image 3 of 3
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
Rett Triplett
801 Reputation
8 Guides authored
Clemson, Team 13-6, Benson Fall 2013 Member of Clemson, Team 13-6, Benson Fall 2013
CLEM-BENSON-F13S13G6
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 590
