Introduction
The Polaroid a520 Camera cover may be removed/disassembled by the consumer at home, with no need for manufacturer involvement. This guide will assist users in the process by showing step-by-step which components should be removed for this purpose.
Note: this guide is only for the purpose of aiding in repairs to the Polaroid a520, and only for repairs that may be accessed through the battery cover.
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Under the screen, locate the black plastic strip that sits above the white plastic strip.
Remove the four 6mm screws from the inner casing using a Phillips #00 screwdriver.
