Disassembling Power Mac G5 Side Panel
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Disassembling Power Mac G5 Side Panel, Side Panel: step 1, image 1 of 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Disassembling Power Mac G5 Side Panel: step 2, image 1 of 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Disassembling Power Mac G5 Side Panel: step 3, image 1 of 2 Disassembling Power Mac G5 Side Panel: step 3, image 2 of 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Disassembling Power Mac G5 Side Panel: step 4, image 1 of 3 Disassembling Power Mac G5 Side Panel: step 4, image 2 of 3 Disassembling Power Mac G5 Side Panel: step 4, image 3 of 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
Finish Line
2 other people completed this guide.
Jessica Chaidez
8,052 Reputation
3 Guides authored
Cal Poly, Team 5-8, Forte Winter 2010 Member of Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 Members
30 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,659
