Disassembling Qualcomm QCP-2760 Rear Backing
  1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: step 1, image 1 of 1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: step 2, image 1 of 2 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: step 2, image 2 of 2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
Xavier
313 Reputation
3 Guides authored
Ohio State, Team 1-4, Buehl Fall 2014 Member of Ohio State, Team 1-4, Buehl Fall 2014
OSU-BUEHL-F14S1G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 215
