Disassembling RCA CC310 Left Cover
  1. Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: step 1, image 1 of 2 Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: step 1, image 2 of 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. Disassembling RCA CC310 Left Cover: step 2, image 1 of 2 Disassembling RCA CC310 Left Cover: step 2, image 2 of 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. Disassembling RCA CC310 Left Cover: step 3, image 1 of 2 Disassembling RCA CC310 Left Cover: step 3, image 2 of 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. Disassembling RCA CC310 Left Cover: step 4, image 1 of 2 Disassembling RCA CC310 Left Cover: step 4, image 2 of 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
Ashley Katchadourian
133 Reputation
1 Guide authored
Cal Poly, Team 5-20, Amido Winter 2011 Member of Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 1,160
