Disassembling Razer Basilisk X Hyperspeed Top Case
    • First heat up the underside of the device, so the glue of the stickers softens up.
  1. Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: step 2, image 1 of 3 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: step 2, image 2 of 3 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: step 2, image 3 of 3
    • Remove the bottom sticker underneath the switch and the big one in the middle. You can drip isopropyl alcohol along the edges of the stickers to make them even easier to remove.
  2. Disassembling Razer Basilisk X Hyperspeed Top Case, Unscrew: step 3, image 1 of 1
    • Remove all 4 screws.
  3. Disassembling Razer Basilisk X Hyperspeed Top Case, Remove the Top: step 4, image 1 of 2 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove the Top: step 4, image 2 of 2
    • Start by gently prying open the case from the bottom. Once the top case becomes loose, you will notice two white wire connectors. Carefully disconnect these to proceed.
  4. Disassembling Razer Basilisk X Hyperspeed Top Case, Admire your work: step 5, image 1 of 1
    • And your done.
Oliver
97 Reputation
1 Guide authored
Global Fixers Member of Global Fixers
Community
35 Members
603 Guides authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 46
Past 30 Days: 195
All Time: 570
