Disassembling Samsung Captivate Glide Phone
  1. Disassembling Samsung Captivate Glide Phone, Phone: step 1, image 1 of 3 Disassembling Samsung Captivate Glide Phone, Phone: step 1, image 2 of 3 Disassembling Samsung Captivate Glide Phone, Phone: step 1, image 3 of 3
    • The Samsung Captivate Glide is fairly easy to take apart and replace any of the modular internal components
  2. Disassembling Samsung Captivate Glide Phone, Battery Removal: step 2, image 1 of 3 Disassembling Samsung Captivate Glide Phone, Battery Removal: step 2, image 2 of 3 Disassembling Samsung Captivate Glide Phone, Battery Removal: step 2, image 3 of 3
    • First remove the battery
  3. Disassembling Samsung Captivate Glide Phone, Unscrewing the Back: step 3, image 1 of 1
    • Using the Phillips #00 screwdriver remove the seven screws indicated here.
  4. Disassembling Samsung Captivate Glide Phone, Prying Up The Back: step 4, image 1 of 3 Disassembling Samsung Captivate Glide Phone, Prying Up The Back: step 4, image 2 of 3 Disassembling Samsung Captivate Glide Phone, Prying Up The Back: step 4, image 3 of 3
    • Plastic molded clips hold the back panel in place and can be removed by first inserting the plastic opening tool into the indicated locations and prying up to pop the back up.
    • Then using a wider lipped plastic opening tool pry the outside of the housing up and the back will remove cleanly.
  5. Disassembling Samsung Captivate Glide Phone, The Phone's Innards: step 5, image 1 of 3 Disassembling Samsung Captivate Glide Phone, The Phone's Innards: step 5, image 2 of 3 Disassembling Samsung Captivate Glide Phone, The Phone's Innards: step 5, image 3 of 3
    • Shown here are internals of the phone.
  6. Disassembling Samsung Captivate Glide Phone, Motherboard Removal: step 6, image 1 of 3 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: step 6, image 2 of 3 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: step 6, image 3 of 3
    • In order to remove the motherboard remove a single screw with the phillips #00 screwdriver, gently pry up the two pop connectors on the board, and finally pull off the coaxial cable.
  7. Disassembling Samsung Captivate Glide Phone, Motherboard Removal: step 7, image 1 of 2 Disassembling Samsung Captivate Glide Phone, Motherboard Removal: step 7, image 2 of 2
    • The motherboard comes out of the phone body easily.
  8. Disassembling Samsung Captivate Glide Phone, Daughterboard Removal: step 8, image 1 of 2 Disassembling Samsung Captivate Glide Phone, Daughterboard Removal: step 8, image 2 of 2
    • The modular pieces of the motherboard are easily removed and replaced as needed.
    • First the daughter board containing the SIM card and microSD card can be removed by disconnecting a single pop connector from the board and then gently pry the daughter board up and it will come loose. It is held down to the motherboard by the stamped metal board level shielding cages.
  9. Disassembling Samsung Captivate Glide Phone, Camera Removal: step 9, image 1 of 1
    • The camera can be easily removed from the motherboard by pulling up on the board pop connector.
  10. Disassembling Samsung Captivate Glide Phone, Speaker Removal: step 10, image 1 of 1
    • The speaker is also easily removed by pulling up on the pop connector.
  11. Disassembling Samsung Captivate Glide Phone, The Disassembled Motherboard: step 11, image 1 of 2 Disassembling Samsung Captivate Glide Phone, The Disassembled Motherboard: step 11, image 2 of 2
    • Shown here are all the pieces of the motherboard.
  12. Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: step 12, image 1 of 3 Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: step 12, image 2 of 3 Disassembling Samsung Captivate Glide Phone, Antenna Module Removal: step 12, image 3 of 3
    • The antenna module can be removed by disconnecting the coaxial cable and a single phillips #00 screw.
    • The antenna module can be prying upward at the location indicated.
  13. Disassembling Samsung Captivate Glide Phone, Antenna Module: step 13, image 1 of 1
    • Shown here is the antenna module.
  14. Disassembling Samsung Captivate Glide Phone, Base and Screen: step 14, image 1 of 1
    • The screen and base are shown here.
3 other people completed this guide.
alcs99
5,075 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 3,319
