Disassembling Samsung Gravity SGH-T459 Rear Case
  1. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Back Cover: step 1, image 1 of 1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459  Rear Case, Disassembling Samsung Gravity SGH-T459  Battery: step 2, image 1 of 1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: step 3, image 1 of 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: step 3, image 2 of 3 Disassembling Samsung Gravity SGH-T459  Rear Case, Rear Case: step 3, image 3 of 3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 387
