Disassembling Samsung Gravity SGH-T459 Keypad
  1. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Back Cover: step 1, image 1 of 1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 Keypad, Disassembling Samsung Gravity SGH-T459  Battery: step 2, image 1 of 1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: step 3, image 1 of 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: step 3, image 2 of 3 Disassembling Samsung Gravity SGH-T459 Keypad, Rear Case: step 3, image 3 of 3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: step 4, image 1 of 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: step 4, image 2 of 3 Disassembling Samsung Gravity SGH-T459 Keypad, Keypad: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Gently remove the two button contacts with your fingers.
    • Use a plastic prying tool to pry the keypad away from the circuit board.
    • Use tweezers to gently remove the keypad.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 757
