Disassembling Samsung Refrigerator RF4287HA** Door
  1. Disassembling Samsung Refrigerator RF4287HA** Door, Remove Cap Top: step 1, image 1 of 1
    • With the door open, use a flathead screwdriver to remove the "Cap Top Table"
    • Be gentle and take care not to scratch or damage the plastic parts.
  2. Disassembling Samsung Refrigerator RF4287HA** Door, Door Disassembly: step 2, image 1 of 1
    • Remove the 3 screws from the top that hold down the "Top Table"
    • Remove the Top Table
  3. Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect: step 3, image 1 of 3 Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect: step 3, image 2 of 3 Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect: step 3, image 3 of 3
    • Disconnect the electrical connector located above the upper left door hinge.
    • To disconnect the connector, press the raised end of the white part while pulling out.
    • Make sure to unplug the appliance before disconnecting anything.
    • Disconnect the water tube by pulling the tube fitting out away from the white plastic connector.
  4. Disassembling Samsung Refrigerator RF4287HA** Door, Left Door Hinge Disconnect (Continued): step 4, image 1 of 1
    • Using a Philips Head Screwdriver, remove the grounding screws.
    • Use a 10mm Socket Wrench to remove the 3 hex bolts.
  5. Disassembling Samsung Refrigerator RF4287HA** Door, Right Door Hinge: step 5, image 1 of 1
    • Disconnect the LED Housing using a Philips Head Screwdriver
    • Remove the ground screws using a Philips Head Screwdriver
    • Remove the 3 HEX bolts using a 10mm socket wrench.
  6. Disassembling Samsung Refrigerator RF4287HA** Door, Door Removal: step 6, image 1 of 2 Disassembling Samsung Refrigerator RF4287HA** Door, Door Removal: step 6, image 2 of 2
    • Remove the lower left and right door hinges using a Philips Head Screwdriver. Use a 10mm wrench to remove the 2 flathead screws.
    • To remove the door, lift it straight up.
Matt Zieminski
38,507 Reputation
13 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,066 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 21
All Time: 86
