Disassembling Samsung SPH-A760 Screen
  1. Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Battery: step 1, image 1 of 2 Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Battery: step 1, image 2 of 2
    • Push open the latch and remove the battery.
  2. Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Antenna: step 2, image 1 of 2 Disassembling Samsung SPH-A760 Screen, Disassembling Samsung SPH-A760 Antenna: step 2, image 2 of 2
    • Twist off the antenna.
    • Pop off the transparent cylinder.
  3. Disassembling Samsung SPH-A760 Screen, Logic Board: step 3, image 1 of 1
    • Remove the five screws as shown.
  4. Disassembling Samsung SPH-A760 Screen: step 4, image 1 of 1
    • Carefully pry the back plate off.
  5. Disassembling Samsung SPH-A760 Screen: step 5, image 1 of 2 Disassembling Samsung SPH-A760 Screen: step 5, image 2 of 2
    • Carefully detach golden screen connector.
  6. Disassembling Samsung SPH-A760 Screen: step 6, image 1 of 2 Disassembling Samsung SPH-A760 Screen: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Pop out the logic board with spudger.
    • Caution: Do not touch with bare hands, use tweezers or wash hands before contact.
  7. Disassembling Samsung SPH-A760 Screen: step 7, image 1 of 2 Disassembling Samsung SPH-A760 Screen: step 7, image 2 of 2
    • Place the logic board on a clean tray.
  8. Disassembling Samsung SPH-A760 Screen, Speakers: step 8, image 1 of 2 Disassembling Samsung SPH-A760 Screen, Speakers: step 8, image 2 of 2
    • Remove the hinge on the phone.
    • Put pressure on the spring with the screwdriver to unhinge phone.
    • Make sure to pull the gold wire through, don't let it rip.
  9. Disassembling Samsung SPH-A760 Screen: step 9, image 1 of 3 Disassembling Samsung SPH-A760 Screen: step 9, image 2 of 3 Disassembling Samsung SPH-A760 Screen: step 9, image 3 of 3
    • Remove the four screws as shown
    • Use the spudger to pry it open, excessive force may be necessary.
  10. Disassembling Samsung SPH-A760 Screen: step 10, image 1 of 3 Disassembling Samsung SPH-A760 Screen: step 10, image 2 of 3 Disassembling Samsung SPH-A760 Screen: step 10, image 3 of 3
    • Remove the three screws that hold the big speaker
    • Caution: The wires are attached to the screen and should be removed with care.
  11. Disassembling Samsung SPH-A760 Screen, Screen: step 11, image 1 of 2 Disassembling Samsung SPH-A760 Screen, Screen: step 11, image 2 of 2
    • Remove the three screws as shown.
    • Pull off the metal bracket.
  12. Disassembling Samsung SPH-A760 Screen: step 12, image 1 of 3 Disassembling Samsung SPH-A760 Screen: step 12, image 2 of 3 Disassembling Samsung SPH-A760 Screen: step 12, image 3 of 3
    • Use the spudger to pop off the screen.
    • Pop off the Microphone/Speaker as well.
    • Place all of the components on a clean tray and clean environment.
David
25 Reputation
6 Guides authored
Cal Poly, Team 10-43, Garner Spring 2010 Member of Cal Poly, Team 10-43, Garner Spring 2010
CPSU-GARNER-S10S10G43
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,925
