Disassembling Samsung TFT Color YP-T7J Removing the Front Cover
  1. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: step 1, image 1 of 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: step 1, image 2 of 2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 2, image 1 of 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 2, image 2 of 2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 3, image 1 of 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 3, image 2 of 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 3, image 3 of 3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: step 4, image 1 of 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: step 4, image 2 of 2
    • Using the philips screwdriver, remove the two screws on the mother board.
  5. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 5, image 1 of 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 5, image 2 of 3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 5, image 3 of 3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  6. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 6, image 1 of 1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  7. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 7, image 1 of 2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: step 7, image 2 of 2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
Jason Farr
353 Reputation
3 Guides authored
Clemson, Team 14-8, Benson Fall 2013 Member of Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 267
