Disassembling Sanyo SCP-8100 Back Panel
  1. Disassembling Sanyo SCP-8100 Back Panel, Battery: step 1, image 1 of 3 Disassembling Sanyo SCP-8100 Back Panel, Battery: step 1, image 2 of 3 Disassembling Sanyo SCP-8100 Back Panel, Battery: step 1, image 3 of 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Disassembling Sanyo SCP-8100 Back Panel, Back Panel: step 2, image 1 of 2 Disassembling Sanyo SCP-8100 Back Panel, Back Panel: step 2, image 2 of 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Disassembling Sanyo SCP-8100 Back Panel: step 3, image 1 of 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Disassembling Sanyo SCP-8100 Back Panel: step 4, image 1 of 2 Disassembling Sanyo SCP-8100 Back Panel: step 4, image 2 of 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Disassembling Sanyo SCP-8100 Back Panel: step 5, image 1 of 3 Disassembling Sanyo SCP-8100 Back Panel: step 5, image 2 of 3 Disassembling Sanyo SCP-8100 Back Panel: step 5, image 3 of 3
    • While removing the back panel, take out the rubber cover on each side.
Yemane
11 Reputation
1 Guide authored
Cal Poly, Team 10-41, Amido Spring 2013 Member of Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 478
