Disassembling Sanyo VPC-T850 Outer Casing
  1. Disassembling Sanyo VPC-T850 Outer Casing, Disassembling Sanyo VPC-T850 Outer Casing: step 1, image 1 of 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: step 2, image 1 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: step 2, image 2 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: step 2, image 3 of 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: step 3, image 1 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: step 3, image 2 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: step 3, image 3 of 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Disassembling Sanyo VPC-T850 Outer Casing: step 4, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Disassembling Sanyo VPC-T850 Outer Casing: step 5, image 1 of 1
    • Separate the rear panel from the rest of the camera.
  6. Disassembling Sanyo VPC-T850 Outer Casing: step 6, image 1 of 2 Disassembling Sanyo VPC-T850 Outer Casing: step 6, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Disassembling Sanyo VPC-T850 Outer Casing: step 7, image 1 of 2 Disassembling Sanyo VPC-T850 Outer Casing: step 7, image 2 of 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: step 8, image 1 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: step 8, image 2 of 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: step 8, image 3 of 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
Jonathan Yau
26 Reputation
4 Guides authored
Cal Poly, Team 27-95, Amido Spring 2010 Member of Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,065
