Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
Christine Becker
Christine Becker and 7 other contributors
Last updated on February 27, 2025
5 - 10 minutes
Easy
Introduction
Go to step 1
This guide acts as a prerequisite for the guides following it. This will show you how to disassemble to phone enclosure in order to access the internal components of the device.
Tools
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: step 1, image 1 of 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 2, image 1 of 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 2, image 2 of 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 3, image 1 of 1
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 4, image 1 of 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 4, image 2 of 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 5, image 1 of 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 5, image 2 of 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 6, image 1 of 1
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 7, image 1 of 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 7, image 2 of 2
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 8, image 1 of 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 8, image 2 of 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 9, image 1 of 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 9, image 2 of 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 9, image 3 of 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 10, image 1 of 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 10, image 2 of 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: step 10, image 3 of 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
3 other people completed this guide.
Christine Becker
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 3,668
