Disassembling Sony Vaio VGN-FW 590 Audio USB Board
  1. Disassembling Sony Vaio VGN-FW 590 Audio USB Board, Audio USB Board: step 1, image 1 of 1
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: step 2, image 1 of 1
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: step 3, image 1 of 1
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: step 4, image 1 of 1
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  5. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: step 5, image 1 of 1
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  6. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: step 6, image 1 of 1
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  7. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: step 7, image 1 of 1
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
8 other people completed this guide.
Artem Nikulkov
313 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 10
All Time: 21,191
