Disassembling UPS OVISLINK TRACITE CUBE or CUBO All
  1. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Unscrew the front panel: step 1, image 1 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Unscrew the front panel: step 1, image 2 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Unscrew the front panel: step 1, image 3 of 3
    • Before you begin, be sure to shut off the UPS and unplug it. You do not want the UPS to kick in while you're performing the procedure.
    • Remove the screws (2) under the device
  2. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Open the front pannel: step 2, image 1 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Open the front pannel: step 2, image 2 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Open the front pannel: step 2, image 3 of 3
    • Slide the front pannel up
  3. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Bottom pannel: step 3, image 1 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Bottom pannel: step 3, image 2 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Bottom pannel: step 3, image 3 of 3
    • Remove left/right clips. And remove the bottom pannel
  4. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the Battery: step 4, image 1 of 1
    • Be careful
  5. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the left side: step 5, image 1 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the left side: step 5, image 2 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the left side: step 5, image 3 of 3
    • Unclip the left pannel
  6. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the right side: step 6, image 1 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the right side: step 6, image 2 of 3 Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the right side: step 6, image 3 of 3
    • Unclip the right pannel
  7. Disassembling UPS OVISLINK TRACITE CUBE or CUBO All, Remove the rear pannel: step 7, image 1 of 1
    • Caution when pluging the rear pannel...
    • -blue for neutral.
    • -yelow/green for earth
    • -brown for phase
2 other people completed this guide.
pldestin
128 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 1,250
