Disassembling VTech MobiGo Touch Learning System Screen Enclosure
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: step 1, image 1 of 1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 2, image 1 of 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 2, image 2 of 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 3, image 1 of 2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 3, image 2 of 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 4, image 1 of 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 5, image 1 of 1
    • Remove the three "L" shaped brackets and the spring.
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 6, image 1 of 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 7, image 1 of 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
2 other people completed this guide.
Daniel Kresge
385 Reputation
4 Guides authored
USF Tampa, Team 8-3, Eyestone Fall 2015 Member of USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Members
17 Guides authored
1 Guide Comment
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - Reply
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 2,434
