This teardown is not a repair guide. To repair your Oregon Scientific Ultra Thin Weather Station, use our service manual.
  1. Disassembling Weather Box Oregon BAR800, Disassembling Weather Box Oregon BAR800: step 1, image 1 of 1
    • Weather Box, front side
  2. Disassembling Weather Box Oregon BAR800: step 2, image 1 of 3 Disassembling Weather Box Oregon BAR800: step 2, image 2 of 3 Disassembling Weather Box Oregon BAR800: step 2, image 3 of 3
    • Rear side
  3. Disassembling Weather Box Oregon BAR800: step 3, image 1 of 1
    • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
    • Be carefull to not damage external plastic with knife
  4. Disassembling Weather Box Oregon BAR800: step 4, image 1 of 3 Disassembling Weather Box Oregon BAR800: step 4, image 2 of 3 Disassembling Weather Box Oregon BAR800: step 4, image 3 of 3
    • After plastic screen removed, it can see the screws.
    • With a small screw driver, take them off. There are eight screws.
  5. Disassembling Weather Box Oregon BAR800: step 5, image 1 of 1
    • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
  6. Disassembling Weather Box Oregon BAR800: step 6, image 1 of 3 Disassembling Weather Box Oregon BAR800: step 6, image 2 of 3 Disassembling Weather Box Oregon BAR800: step 6, image 3 of 3
    • Internal view
Andres
110 Reputation
1 Guide authored
10 Comments
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - Reply
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel -
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
To solve the missing digits and segments on the LCD, in my case I just inserted a small bent paper on the flat white cable (strip) to add a small bit of more pressure into the connectors.
You can read more on Stackexchange searching for partially-broken-lcd-missing-segments
JCM -
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 18
All Time: 3,265
