Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard
  1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: step 1, image 1 of 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: step 1, image 2 of 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: step 1, image 3 of 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: step 2, image 1 of 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: step 2, image 2 of 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, LED Light conducting plastic pieces: step 3, image 1 of 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: step 4, image 1 of 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: step 4, image 2 of 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: step 4, image 3 of 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: step 5, image 1 of 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: step 5, image 2 of 2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: step 6, image 1 of 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: step 6, image 2 of 2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: step 7, image 1 of 1
    • Remove the rubber piece from the SATA/USB bridge logic board.
  8. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: step 8, image 1 of 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: step 8, image 2 of 2
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  9. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: step 9, image 1 of 1
    • Remove both screws holding the retaining plate with the logic board.
Gaetan
9,577 Reputation
18 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 2,027
