This teardown is not a repair guide. To repair your iClicker, use our service manual.
  1. Disassembling iClicker Device, Disassembling iClicker Device: step 1, image 1 of 1
    • Behold the iclicker in all its interactive and educational beauty.
  2. Disassembling iClicker Device: step 2, image 1 of 1
    • Place the device on a flat surface, buttons facing down.
    • Remove the battery cover and the three batteries within.
  3. Disassembling iClicker Device: step 3, image 1 of 2 Disassembling iClicker Device: step 3, image 2 of 2
    • Remove the two visible screws using a #00 Phillips screwdriver.
    • Oops! Don't forget a hidden third screw beneath the factory label.
    • Peel back the corner of the label to reveal the hidden screw.
    • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
  4. Disassembling iClicker Device: step 4, image 1 of 2 Disassembling iClicker Device: step 4, image 2 of 2
    • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
    • For the more resistent iclickers, a spudger may be employed to separate the pieces.
  5. Disassembling iClicker Device: step 5, image 1 of 1
    • Your iclicker is now exposed for all its worth.
    • The back panel can be set aisde, as the remaining components are housed in the front panel.
  6. Disassembling iClicker Device: step 6, image 1 of 2 Disassembling iClicker Device: step 6, image 2 of 2
    • Using a spudger, gently pry the battery connectors from the front panel.
  7. Disassembling iClicker Device: step 7, image 1 of 1
    • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
  8. Disassembling iClicker Device: step 8, image 1 of 1
    • The buttons can be easily removed from the front assembly sans spudger.
  9. Disassembling iClicker Device: step 9, image 1 of 1
    • Don't lose the small LED cover sitting precariously in the front panel.
  10. Disassembling iClicker Device: step 10, image 1 of 1
    • Your iclicker is now disassembled.
1 Guide Comment
What is an iClicker ?
furbies - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 8,003
