Disassembling mouse PERIXX PERIMICE-719
  1. Disassembling mouse PERIXX PERIMICE-719, PERIXX PERIMICE-719: step 1, image 1 of 1
    • Remove these four screws. Two are in the battery compartment; the other two are under the label.
  2. Disassembling mouse PERIXX PERIMICE-719: step 2, image 1 of 1
    • Unplug this ribbon cable.
  3. Disassembling mouse PERIXX PERIMICE-719: step 3, image 1 of 2 Disassembling mouse PERIXX PERIMICE-719: step 3, image 2 of 2
    • Look for these two plastic tabs that move when you click the left and right mouse buttons. Push them forwards (towards the front of the mouse) to release the buttons from the top case.
  4. Disassembling mouse PERIXX PERIMICE-719: step 4, image 1 of 1
    • Push these two retainer tabs to release the button assembly from the top case.
  5. Disassembling mouse PERIXX PERIMICE-719: step 5, image 1 of 1
    • Remove these two screws, then pull apart the two halves of the top case.
  6. Disassembling mouse PERIXX PERIMICE-719: step 6, image 1 of 1
    • Remove these two screws and pull off the PCB.
  7. Disassembling mouse PERIXX PERIMICE-719: step 7, image 1 of 3 Disassembling mouse PERIXX PERIMICE-719: step 7, image 2 of 3 Disassembling mouse PERIXX PERIMICE-719: step 7, image 3 of 3
    • The scroll wheel uses a 13mm mechanical encoder made by TTC. The buttons use microswitches made by Huano. Replacements readily available from eBay or AliExpress.
  8. Disassembling mouse PERIXX PERIMICE-719: step 8, image 1 of 1
    • Nothing too interesting here.
Li-Wen Yip
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 28
