Disassembling the Ematic Genesis
  1. Disassembling the Ematic Genesis, Ematic Genesis Casing: step 1, image 1 of 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: step 1, image 2 of 3 Disassembling the Ematic Genesis, Ematic Genesis Casing: step 1, image 3 of 3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Disassembling the Ematic Genesis: step 2, image 1 of 3 Disassembling the Ematic Genesis: step 2, image 2 of 3 Disassembling the Ematic Genesis: step 2, image 3 of 3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Disassembling the Ematic Genesis: step 3, image 1 of 1
    • Remove back plate from screen plate and lay both down flat next to each other.
Justin Rohrman
745 Reputation
6 Guides authored
Baylor, Team 4-3, Williams Spring 2015 Member of Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 415
