Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner
  1. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Handle Extension: step 1, image 1 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Handle Extension: step 1, image 2 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Handle Extension: step 1, image 3 of 3
    • Find the gray tab, directly above the power switch, where the blue body of the vacuum meets the gray handle extension
    • Lift the tab and pull the gray extension bar away from the blue body
  2. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Vacuum Foot: step 2, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Vacuum Foot: step 2, image 2 of 2
    • Remove the vacuum foot from the main body by gripping each piece firmly and strongly pulling them apart
  3. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Unscrew Base Plate of Foot: step 3, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Unscrew Base Plate of Foot: step 3, image 2 of 2
    • Using a number 2 Phillips head screwdriver, remove the 6 screws from the base plate of the vacuum foot
    • Keep track of the screws for later reassembly
  4. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Separate Vacuum Foot: step 4, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Separate Vacuum Foot: step 4, image 2 of 2
    • Grip the top and bottom plate of the vacuum foot firmly
    • Pull the plates apart until they are completely separated.
  5. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Clean Foot Interior: step 5, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Clean Foot Interior: step 5, image 2 of 2
    • Use the medium size brush to remove the dirt from plates of the vacuum foots
    • Because there are not electrical parts of the foot, It is okay to rinse the parts with water and let it dry instead of brushing
  6. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Release Main Body Filters: step 6, image 1 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Release Main Body Filters: step 6, image 2 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Release Main Body Filters: step 6, image 3 of 3
    • Press the indented side of the center gray latch
    • Using your other hand carefully separate the nozzle form the motor component
    • There may be dirt and debris in the filter nozzle. Separate the parts with the body slightly tilted up to avoid dirt in your work space
  7. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove and Empty Filter Compartment: step 7, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove and Empty Filter Compartment: step 7, image 2 of 2
    • Firmly pinch the gray center ridge of the filter and pull away from the blue nozzle
    • Be cautious when removing the filter. Dust and dirt will fall out
    • Recommended to do this step over a trashcan or outside
  8. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Peel Back Sticker: step 8, image 1 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Peel Back Sticker: step 8, image 2 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Peel Back Sticker: step 8, image 3 of 3
    • Locate the warning sticker on the bottom of the motor component
    • Fold back half the sticker so that it remains attached to only one side of the component
    • Use the scraper to lift one corner of the warning sticker
  9. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove and Clean Foam Filter: step 9, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove and Clean Foam Filter: step 9, image 2 of 2
    • Remove the foam vent filter. Brush with toothbrush or another small, soft bristle brush to dislodge dirt particles
  10. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Unscrew Motor Casing: step 10, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Unscrew Motor Casing: step 10, image 2 of 2
    • Using a number 2 phillips head screwdriver remove all 7 screws from motor component
  11. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Handle Extension Release Tab: step 11, image 1 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Handle Extension Release Tab: step 11, image 2 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Remove Handle Extension Release Tab: step 11, image 3 of 3
    • With the two halves loosened, pry the halves apart enough to remove the handle extension release tab from the end of the motor component
    • keep track of the latch for later reassembly
  12. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Expose Interior Motor: step 12, image 1 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Expose Interior Motor: step 12, image 2 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Expose Interior Motor: step 12, image 3 of 3
    • Firmly grip both sides of the central component with your hands aligned vertically
    • Pry the two halves apart while being sure the bottom half remains flat.
  13. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Isolate Motor: step 13, image 1 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Isolate Motor: step 13, image 2 of 3 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Isolate Motor: step 13, image 3 of 3
    • Untangle and unwrap any cords and wires from around the motor
    • With the component laying on a flat surface gently lift the motor up and away from the blue plastic
  14. Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Clean Motor: step 14, image 1 of 2 Disassembly and Cleaning of Series 2033 Bissell Featherweight Stick Bagless Vacuum Cleaner, Clean Motor: step 14, image 2 of 2
    • Using the small soft bristle brush, gently brush around the motor to dislodge any loose dirt or debris
2 other people completed this guide.
Brooke Calvo
259 Reputation
1 Guide authored
One Comment
Thank you!!
I was wondering if there was any way to remove the wheels to remove the long hairs that are stuck inbetween.
ThickBurger - Reply
Past 24 Hours: 10
Past 7 Days: 54
Past 30 Days: 235
All Time: 12,607
