Disconnecting Garmin Nuvi 680 Screen Wiring
  1. Disconnecting Garmin Nuvi 680 Screen Wiring, Outer Case: step 1, image 1 of 1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Disconnecting Garmin Nuvi 680 Screen Wiring: step 2, image 1 of 1
    • Remove the antenna cover.
  3. Disconnecting Garmin Nuvi 680 Screen Wiring: step 3, image 1 of 1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Disconnecting Garmin Nuvi 680 Screen Wiring: step 4, image 1 of 2 Disconnecting Garmin Nuvi 680 Screen Wiring: step 4, image 2 of 2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Disconnecting Garmin Nuvi 680 Screen Wiring: step 5, image 1 of 1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Disconnecting Garmin Nuvi 680 Screen Wiring: step 6, image 1 of 2 Disconnecting Garmin Nuvi 680 Screen Wiring: step 6, image 2 of 2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Disconnecting Garmin Nuvi 680 Screen Wiring, Antenna: step 7, image 1 of 2 Disconnecting Garmin Nuvi 680 Screen Wiring, Antenna: step 7, image 2 of 2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Disconnecting Garmin Nuvi 680 Screen Wiring, Screen Wiring: step 8, image 1 of 1
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Disconnecting Garmin Nuvi 680 Screen Wiring: step 9, image 1 of 2 Disconnecting Garmin Nuvi 680 Screen Wiring: step 9, image 2 of 2
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
Allen Pasch
261 Reputation
1 Guide authored
Cal Poly, Team 5-22, Amido Winter 2011 Member of Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,497
