Disconnecting the Battery
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Disconnecting the Battery, Bottom Cover: step 1, image 1 of 2 Disconnecting the Battery, Bottom Cover: step 1, image 2 of 2
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Disconnecting the Battery: step 2, image 1 of 3 Disconnecting the Battery: step 2, image 2 of 3 Disconnecting the Battery: step 2, image 3 of 3
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
  3. Disconnecting the Battery, Disconnecting the Battery: step 3, image 1 of 3 Disconnecting the Battery, Disconnecting the Battery: step 3, image 2 of 3 Disconnecting the Battery, Disconnecting the Battery: step 3, image 3 of 3
    • Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
    • Once loosened, pull back on the tape to remove it from the connector.
    • Use a plastic spudger to pull the battery connector away from the motherboard.
    • Leave the battery unplugged for the following steps.
  4. Disconnecting the Battery: step 4, image 1 of 2 Disconnecting the Battery: step 4, image 2 of 2
    • Press and hold the laptop's power button for about five seconds to discharge any remaining power in the system.
    • Do not touch any exposed components while carrying out this step or put them in contact with conductive materials.
    • Leave the battery connector unplugged and out of the way for the rest of the time the laptop is open.
Attached Documents
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
