Introduction
If most of the coffee runs into the bowl, the seals in the drain valve may be hardened or the white cap on the valve plunger may be cracked. Here we show you how to replace them.
The brewing group has already been removed and disassembled. Now it's time for the drainage valve.
There will be many pictures
All you need a small flathead screwdriver.
When assembling, make sure that the lips of the seals point to the pressure side, i.e. inward, and the flat side outward.
When installing, make sure that the pressure hose runs through the slot in the valve carrier.
Apply a thin layer of food-safe silicone grease to the seals before installation.
Follow the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
