Display Assembly
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Disconnect the antenna cable.
    • Close the display.
    • Turn the computer upside down with the back of the computer facing you.
  1. Display Assembly, Remove the Screws: step 2, image 1 of 1
    • From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  2. Display Assembly, Remove the Screws: step 3, image 1 of 2 Display Assembly, Remove the Screws: step 3, image 2 of 2
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  3. Display Assembly, Removing the Cables: step 4, image 1 of 1
    • Turn the computer right-side up and open the display.
    • Carefully remove the antenna cable and the display cables from their routing guides.
  4. Display Assembly, Lifting the Display Assembly: step 5, image 1 of 1
    • NOTICE: Be careful not to damage the display switch when removing the display.
    • Lift the display assembly out of the computer base.
Terrence15
79,858 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
43 Members
1,993 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 700
