Dissolved Oxygen Node Assembly
  1. Dissolved Oxygen Node Assembly, Outside Enclosure and Solar Panel: step 1, image 1 of 1
    • Refer to steps 2-5, 6-7, and 20-21 in the Depth Sensor Node Enclosure Assembly to attach the solar panel to the node enclosure.
    • Use the same enclosure provided in the node enclosure assembly guide with the same cut out holes.
  2. Dissolved Oxygen Node Assembly, Temperature Board and Adapter: step 2, image 1 of 3 Dissolved Oxygen Node Assembly, Temperature Board and Adapter: step 2, image 2 of 3 Dissolved Oxygen Node Assembly, Temperature Board and Adapter: step 2, image 3 of 3
    • Locate the old style electrically isolated carrier board. If pins are soldered on, remove and solder on a 2 and 3 plug header or one 5-plug header.
    • Once the new attachments are soldered on, proceed to put the temperature circuit board into the connection holes. The black square of the circuit board should face towards the soldered attachments.
    • Cut wires to approximately 6 1/2 inches to allow enough length to secure the wires into the 5-plug header.
    • Refer to the temperature section of the wiring diagram when wiring the adapter.
  3. Dissolved Oxygen Node Assembly, Dissolved Oxygen Board and Adapter: step 3, image 1 of 3 Dissolved Oxygen Node Assembly, Dissolved Oxygen Board and Adapter: step 3, image 2 of 3 Dissolved Oxygen Node Assembly, Dissolved Oxygen Board and Adapter: step 3, image 3 of 3
    • Locate the new style electrically isolated carrier board.
    • Locate the Dissolved Oxygen circuit board and place the board into the connection holes. The black square of the circuit board should face towards the pins.
    • Refer to the DO section of the wiring diagram when wiring the adapter.
  4. Dissolved Oxygen Node Assembly, Cable Gland: step 4, image 1 of 2 Dissolved Oxygen Node Assembly, Cable Gland: step 4, image 2 of 2
    • Obtain the cable gland.
    • Screw the cable gland into the wall of the enclosure, through the large hole, as shown.
  5. Dissolved Oxygen Node Assembly, Velcro Attachments: step 5, image 1 of 2 Dissolved Oxygen Node Assembly, Velcro Attachments: step 5, image 2 of 2
    • Insert velcro strips with soft sides inside of the enclosure in the following places
    • Attach velcro with rough side onto the back of the adapters.
  6. Dissolved Oxygen Node Assembly, Wiring the sensors: step 6, image 1 of 3 Dissolved Oxygen Node Assembly, Wiring the sensors: step 6, image 2 of 3 Dissolved Oxygen Node Assembly, Wiring the sensors: step 6, image 3 of 3
    • Locate the Atlas DO sensor
    • Locate the Atlas PT-1000 Temperature Sensor
    • Obtain four 1.5-inch long standoffs and 4 1-inch long standoffs. Screw the standoffs together as shown, to make four 2.5-inch long standoffs
    • Thread the wires of the sensors into the cable gland. Proceed to screw the standoffs into the holes of the enclosure.
  7. Dissolved Oxygen Node Assembly, Battery: step 7, image 1 of 3 Dissolved Oxygen Node Assembly, Battery: step 7, image 2 of 3 Dissolved Oxygen Node Assembly, Battery: step 7, image 3 of 3
    • Obtain one battery, 4 zip ties, foam, and a pair of scissors
    • Cut out two battery-sized pieces of foam
    • Sandwich the battery between the two pieces of foam and secure it using the zip-ties. Connect the zip-ties to make two extra long zip-ties
  8. Dissolved Oxygen Node Assembly, Attaching GPS and Antenna to Modem: step 8, image 1 of 3 Dissolved Oxygen Node Assembly, Attaching GPS and Antenna to Modem: step 8, image 2 of 3 Dissolved Oxygen Node Assembly, Attaching GPS and Antenna to Modem: step 8, image 3 of 3
    • Obtain the cell module (modem), GPS, and antenna
    • Insert Super SIM card into cell module
    • Attach the GPS to the connection shown (grey wire)
    • Attach the antenna to the connection shown (black wire)
  9. Dissolved Oxygen Node Assembly, Adding Velcro to GPS and Antenna: step 9, image 1 of 1
    • Attach rough-sided velcro on the antenna and GPS as shown in the picture.
  10. Dissolved Oxygen Node Assembly, Board: step 10, image 1 of 3 Dissolved Oxygen Node Assembly, Board: step 10, image 2 of 3 Dissolved Oxygen Node Assembly, Board: step 10, image 3 of 3
    • Obtain Open-Storm board and place 4 jumpers in the spots shown
    • Insert microSD card into board
    • Attach the cellular module onto the sensor node board in the appropriate place
  11. Dissolved Oxygen Node Assembly, Assembling the Node Interior: step 11, image 1 of 3 Dissolved Oxygen Node Assembly, Assembling the Node Interior: step 11, image 2 of 3 Dissolved Oxygen Node Assembly, Assembling the Node Interior: step 11, image 3 of 3
    • Put the battery into the node enclosure between the area of the standoffs
    • Place the board with the modem and the GPS antenna onto the standoffs and GENTLY screw the board in place. Then stick the modem and GPS in the locations highlighted.
    • Stick the carrier boards onto the sides of the interior. Make sure to place the carrier in their respective location highlighted.
    • Follow the wiring diagram when wiring the carrier boards to the circuit board.
  12. Dissolved Oxygen Node Assembly, Adjusting Solar Charger Potentiometer: step 12, image 1 of 3 Dissolved Oxygen Node Assembly, Adjusting Solar Charger Potentiometer: step 12, image 2 of 3 Dissolved Oxygen Node Assembly, Adjusting Solar Charger Potentiometer: step 12, image 3 of 3
    • Obtain USB power supply, plug into a laptop, and set output to 5.9V
    • Check the voltage with a voltmeter (you may have to set the power supply to ~5.8V for the voltmeter to read 5.9V)
    • Plug in the green terminal block from the power supply into the Open-Storm board solar port.
    • Confirm the solar charge LED is off.
    • Plug in a dead battery to the battery port. This step will not work with a charged battery
    • CAREFULLY turn the silver potentiometer next to the charge controller IC with a small flathead screw driver until the charge light turns on.
    • Although the screw has a phillip screw head, using a phillip screwdriver may damage the potentiometer. The hole in the center is too shallow for most screwdrivers. It is easier to use a flathead screwdriver!
    • Resource: 1. How to Select MPP Voltage on a Solar Charge Controller 2. Sunny Buddy Solar Charger V13 Hookup Guide
  13. Dissolved Oxygen Node Assembly, Powering the Node: step 13, image 1 of 1
    • Plug in the battery as highlighted
    • Plug in the solar panel as highlighted
    • The lights of the two sensor circuit boards should turn on
  14. Dissolved Oxygen Node Assembly, Applying Open-Storm and Node ID stickers: step 14, image 1 of 1
    • Apply the open-storm sticker to the side of the enclosure as shown
    • Apply the unique node ID sticker to the top as shown
  15. Dissolved Oxygen Node Assembly, Node Handle: step 15, image 1 of 1
  16. Dissolved Oxygen Node Assembly, Node Structure: step 16, image 1 of 3 Dissolved Oxygen Node Assembly, Node Structure: step 16, image 2 of 3 Dissolved Oxygen Node Assembly, Node Structure: step 16, image 3 of 3
    • Locate a 5 foot long steel strut channel
    • Using U-bolts, attach the node handle to the strut channel as shown
  17. Dissolved Oxygen Node Assembly, Node Structure pt. 2: step 17, image 1 of 2 Dissolved Oxygen Node Assembly, Node Structure pt. 2: step 17, image 2 of 2
    • Using a zip tie, tie both of the sensor's cables together. Since the DO's cable is longer, make a loop to shorten its length
    • Using hose clamps, secure the cables and the sensors along the struct channel
  18. Dissolved Oxygen Node Assembly, Preparing the Lock: step 18, image 1 of 1
  19. Dissolved Oxygen Node Assembly, Finishing Touches: step 19, image 1 of 3 Dissolved Oxygen Node Assembly, Finishing Touches: step 19, image 2 of 3 Dissolved Oxygen Node Assembly, Finishing Touches: step 19, image 3 of 3
    • The sensor lights in the node should be turned on
    • Attach the lock to the side of the node
    • Make sure to twist the cable gland so that the wires are snug together
    • If the DO readings emit a reading of 0 mg/L then:
    • Make sure the DO circuit board is facing the correct orientation (refer to step 2)
    • Make sure that the jumper wires are connected correctly and securely. Likewise, check if the RX and TX wires are swapped.
    • Check the connection between the adapter cable and the housing of the DO sensor to see if it is tight and sealed.
    • Make sure there is adequate electrolyte solution in the cap of the DO sensor.
    • If the steps above fail, replace the DO sensor circuit board.
    • If the DO readings emit a reading of 100,000 mg/L then:
    • Replace the DO sensor circuit board.
Brooke Mason
2,958 Reputation
17 Guides authored
Open-Storm Member of Open-Storm
Community
14 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 431
