Parts: (in order from left to right)
Short Screws
Latch mechanism with latch face
Long screws
Door knob with peg and screw holes (inside of the room)
Door knob with screw holes (outside of the room)
Unscrew the screws on the recent knob and once unscrewed you may know take out the knob from the door.
Takeout and install the new latch: Unscrew the latch assembly and remove the latch mechanism from the door. Then insert the new latch into the hole making sure it is facing the right way.
Next you will be placing the exterior knob on the outside and the interior inside and will secure the screws.
Check if the latch properly works and make sure the door open and closes.
