Door Mirror Replacement
  1. Door Mirror Replacement, Door Mirror: step 1, image 1 of 1
    • Use a screwdriver to remove the two brackets securing the top of the mirror.
    • The mirror will fall forward once the two top brackets are released; be sure to support the mirror as you unscrew the brackets.
    • The type of screwdriver needed will depend on your specific brackets.
  2. Door Mirror Replacement: step 2, image 1 of 1
    • Lift the broken mirror off of the door.
    • Remove any cardboard or other cushioning (if any) from the door.
  3. Door Mirror Replacement: step 3, image 1 of 1
    • Loosen, but don't remove, the bottom brackets to accommodate the width of the new mirror.
  4. Door Mirror Replacement: step 4, image 1 of 1
    • If you have new mirror supports, then remove the old brackets entirely and replace them with the new brackets.
  5. Door Mirror Replacement: step 5, image 1 of 1
    • Replace any cushioning behind the mirror.
    • While supporting the top of the mirror, set the mirror into the bottom brackets, then tighten the brackets.
  6. Door Mirror Replacement: step 6, image 1 of 1
    • Replace the top brackets and tighten them to full secure the mirror.
Enjoy your new mirror!
Seth Wanderman
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 31
All Time: 954
