Dopo Double Power 7 Motherboard Replacement
  1. Dopo Double Power 7 Motherboard Replacement, Rear Panel: step 1, image 1 of 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Motherboard Replacement: step 2, image 1 of 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Motherboard Replacement: step 3, image 1 of 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Motherboard Replacement: step 4, image 1 of 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove any static tape covering the motherboard.
  6. Dopo Double Power 7 Motherboard Replacement: step 6, image 1 of 2 Dopo Double Power 7 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
    • The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
    • Once the lever is lifted, pull out the cable by gently tugging on it.
  7. Dopo Double Power 7 Motherboard Replacement: step 7, image 1 of 1
    • Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
  8. Dopo Double Power 7 Motherboard Replacement: step 8, image 1 of 2 Dopo Double Power 7 Motherboard Replacement: step 8, image 2 of 2
    • Using wire cutters, cut the red, black, and grays wires.
    • The motherboard can now be removed
    • Leave enough wire to be re-soldered back if possible.
mike pelosi
682 Reputation
6 Guides authored
UMass Dartmouth, Team 1-2, Miles Fall 2015 Member of UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 499
